The same CoCoHue group works works with Simple Automation Rules, Scenes, etc.
Also, the Button Controller works fine with "Turn On Switch" or "Set The Scene" actions (no errors) - just not with "Set Color and Level"...
I don't have that particular button device but can't replicate this issue with a new instance of BC 3.1 that I set up with another button device. If you try re-creating this automation, I wonder if it might just work; otherwise, I'll tag @bravenel here to see if there's any piece of your setup or logs he might want to troubleshoot this error, which does appear to be originating from BC.
PS - While you didn't ask, you could simply your actions a bit. If they aren't already on, the "Set Color" command will also turn the CoCoHue bulb/group on (unless you happened to enable the pseudo-prestaging option). That would have no bearing on the above issue but will likely make your lights respond better/faster since you aren't sending two group commands in a row, something Hue recommends limiting to 1 per second.
I just created a button controller 3.1 instance with 2 Lightify 4-button switches and my dining room lights (which are on my other HE hub shared via HubConnect). I get errors thrown for every command except off
Unless I click Remove to get rid of the whole thing, this shows anytime I click on this button action afterwords. I cannot go back and change it to something else. "Kitchen Light" is a group of 3 bulbs created by the Hue controller although it did the same when I tested with only 1 bulb selected.
This action works fine in BC 3.0, I was only trying to move to BC 3.1 so that the two Pico's I have in some rooms didn't need separate rules anymore.
Thanks for verifying. I'll wait. I already have it setup in BC 3.0 so it's working. Just wanted to switch over so my rooms with 2 Pico's in them only needed one rule.
I'm now on 2.2.2.129 and not sure if this bug was supposed to be fixed but I still have the same issue. I am moving things over to my new C-7 which is also on 2.2.2.129 and as expected it's having the same issue with BC 3.1. So still getting the same "Unexpected Error" when I attempt to use "Adjust these Dimmers".
@bravenel I am on 2.2.2.129 and still have the same exact problem as before. It's the same issue as @lelynch describes, but I am not using a Pico remote. It's the same issue as the original post. I took your advice and I am using RM for now.
Yes, how many times do I have to say it: Adjust Dimmers has a bug. It will get fixed, but it has not been fixed yet. Use an individual button rule in RM to work around it.
I apologize, but your post leads me to believe that you thought that this issue was resolved. It isn't. I am not rushing you to fix this. I posted that I am using your work around. I was only trying to help. I get that you are stressed, but.....
The final response to my initial report confused me a bit also as you didn't reply back after stating I was on the version asked. Apologize if you feel harassed. It's not my intent. I do read the notes before installing but unless I am missing something, they don't change between minor updates. I guess you are meaning the notes in the community announcement.
