Those all should be the same if they are all using the same driver etc.
If you are feeling experimental, I like these drivers:
You can install them manually by importing the code from Github, or by using Hubitat Package Manager. You would then change the driver to this one, and hit configure in the device setting page.
If you haven't tried Package Manager, it is a simple and excellent way to try new community apps and drivers, and easily maintain apps and drivers.
