Button Contoller 5.1 Error
I'm trying to use the button contoller app to control some Hunter Douglas shades with a Lutron Pico. Previously when I used a Pico to control some lights I used the Rule Machine back a few updates. I loaded the Button Contoller 5.1 app on my C5 and tried to add a rule. The rule gets added but when I try to add a button from the Pico it crashes with this error:
Unexpected Error
An unexpected error has occurred trying to load the app. Check Logs for more information.
Error: App type not found for namespace: hubitat and name: Button Rule-5.1
The log shows:
app:13182021-10-08 11:53:04.959 errorhubitat.exception.NotFoundException: App type not found for namespace: hubitat and name: Button Rule-5.1 on line 144 (method mainPage)
I tried deleting the app and reinstalling but it does the same thing.
I've got the same fault after installing update 2.2.9.128?
Reboot should fix it. Also, there's extra logging in 2.2.9 so now I can hopefully track down the root cause and fix it for good.
Yes, that fixed it, Thank you
