How about a bulb template without the slider? I have many non-dimming lights that would look best on the dashboard with a simple bulb on/off icon. It would behave just like the outlet or switch template with a different icon
I believe you are using a switch to control those, the bulb template is for smart bulbs, then you should use the switch template, I see your point, don't get me wrong, probably in some point on the future they will allow to change icons and scroll the dashboard....
I am using a switch template. A quick fix (that would work for me) would be to simply replicate the switch template with a new icon and call it 'light' or 'lamp'. This could happen before the future plans for more custom template.
