Ran into this today. Found it due to 'Some devices are generating excessive events.' and my two Shelly Pro 1PM were the culprits, might apply to other Shelly devices as well, especially ones with PM. I couldn't find a way to control this from the Shelly side on stock firmware (there's not reporting threshold I could see).
Hub: C-8 Pro, platform 2.5.2.139. Devices: Shelly Pro 1PM (SPSW-201PE16EU), firmware 2.1.1 (20261026-151206/2.1.1-g07e9ad2), driver "Shelly WiFi v2 Switch".
Issue 1: the relay is on continuously (Switch.GetStatus: output: true, counts.switch_on: 1), but the device logs switch off/on several times per second. Debug log shows the driver applying input sections to the switch attribute:
parse [id:0, state:false, sectionName:input:0, sectionType:input] -> switch is now off
parse [id:1, state:null, sectionName:input:1, sectionType:input] -> switch is now off
parse [... switch:0 output:true ...] -> switch is now on
Input config: input:0 type switch, enabled (state false); input:1 disabled (state null). Expected: input sections should not update the relay's switch attribute (and a disabled input with state null should be ignored).
Issue 2: the power reports are arriving too often, up to several per second on every wattage change.
