Built In Minoston Mini Power Meter Plug Driver reporting power draw every second!
Seems like the device is not reporting anything.
Try setting the power report value changed to 5 and also change the minutes to 5, you don't want it reporting every minute.
Whatever you have plugged into it, turn it on and off as well, which should trigger the power report if its over 5w.
