Built-in Ecobee integration - half degree (C) support for setpoints?
Searched the forums and did not find anything directly relevant.
When setting the Ecobee thermostat's (heating) setpoint, the device page (and RM) accept a decimal number, e.g. 19.5, and correctly sets the thermostat to that value (verified on ecobee.com and the thermostat itself).
However it appears the HE built-in device driver doesn't preserve that granularity in the device attribute. The thermostatSetpoint attribute value appears to be rounded up to the nearest integer:
And consequenty, the setpoint change event's value is set to the rounded number
The Ecobee device debug logs hint to it being due to round-trip conversions between C / F in the driver, perhaps ?
Would it be possible to support a single decimal place for the setpoint ?
This conversion happens crossing the Ecobee API, which uses °F. I'm not sure we're doing the conversion of what comes back correctly, and that bears looking into.
FYI, the issue is still present in 2.4.1.x, both latest release and latest beta.
