Built-in Aqara Zigbee Weather Sensor Driver Not Getting Temperature since 2.4.1.151
Since I first saw this when I updated to 2.4.1.151 on a production hub, I have added the same device model to my beta hub and have the same issue so it can be debugged.
Aqara Temperature and Humiidity Sensor, model WSDCGQ11LM
dev:142025-04-03 09:44:51.903 AMinfoAqara Test Sensor pressure is 98.3kPa
dev:142025-04-03 09:44:51.889 AMdebugdescMap: [raw:01B40104031C000029D703140028FF1000296D26, dni:01B4, endpoint:01, cluster:0403, size:1C, attrId:0000, encoding:29, command:0A, value:03D7, clusterInt:1027, attrInt:0, additionalAttrs:[[value:FF, encoding:28, attrId:0014, consumedBytes:4, attrInt:20], [value:266D, encoding:29, attrId:0010, consumedBytes:5, attrInt:16]]]
dev:142025-04-03 09:44:51.886 AMdebugdescription: read attr - raw: 01B40104031C000029D703140028FF1000296D26, dni: 01B4, endpoint: 01, cluster: 0403, size: 1C, attrId: 0000, encoding: 29, command: 0A, value: D703140028FF1000296D26
dev:142025-04-03 09:44:51.886 AMinfoAqara Test Sensor is 55%RH
dev:142025-04-03 09:44:51.883 AMdebugdescMap: [raw:01B40104050A000021DC15, dni:01B4, endpoint:01, cluster:0405, size:0A, attrId:0000, encoding:21, command:0A, value:15DC, clusterInt:1029, attrInt:0]
dev:142025-04-03 09:44:51.880 AMdebugdescription: read attr - raw: 01B40104050A000021DC15, dni: 01B4, endpoint: 01, cluster: 0405, size: 0A, attrId: 0000, encoding: 21, command: 0A, value: DC15
dev:142025-04-03 09:44:51.876 AMdebugdescMap: [raw:01B40104020A000029B908, dni:01B4, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:08B9, clusterInt:1026, attrInt:0]
dev:142025-04-03 09:44:51.874 AMdebugdescription: read attr - raw: 01B40104020A000029B908, dni: 01B4, endpoint: 01, cluster: 0402, size: 0A, attrId: 0000, encoding: 29, command: 0A, value: B908
dev:142025-04-03 09:44:48.715 AMinfoAqara Test Sensor pressure is 98.3kPa
dev:142025-04-03 09:44:48.609 AMdebugdescMap: [raw:01B40104031C000029D703140028FF1000296D26, dni:01B4, endpoint:01, cluster:0403, size:1C, attrId:0000, encoding:29, command:0A, value:03D7, clusterInt:1027, attrInt:0, additionalAttrs:[[value:FF, encoding:28, attrId:0014, consumedBytes:4, attrInt:20], [value:266D, encoding:29, attrId:0010, consumedBytes:5, attrInt:16]]]
dev:142025-04-03 09:44:48.607 AMdebugdescription: read attr - raw: 01B40104031C000029D703140028FF1000296D26, dni: 01B4, endpoint: 01, cluster: 0403, size: 1C, attrId: 0000, encoding: 29, command: 0A, value: D703140028FF1000296D26
dev:142025-04-03 09:44:48.595 AMdebugdescMap: [raw:01B40104050A0000210116, dni:01B4, endpoint:01, cluster:0405, size:0A, attrId:0000, encoding:21, command:0A, value:1601, clusterInt:1029, attrInt:0]
dev:142025-04-03 09:44:48.594 AMdebugdescription: read attr - raw: 01B40104050A0000210116, dni: 01B4, endpoint: 01, cluster: 0405, size: 0A, attrId: 0000, encoding: 21, command: 0A, value: 0116
dev:142025-04-03 09:44:48.589 AMdebugdescMap: [raw:01B40104020A000029B508, dni:01B4, endpoint:01, cluster:0402, size:0A, attrId:0000, encoding:29, command:0A, value:08B5, clusterInt:1026, attrInt:0]
dev:142025-04-03 09:44:48.587 AMdebugdescription: read attr - raw: 01B40104020A000029B508, dni: 01B4, endpoint: 01, cluster: 0402, size: 0A, attrId: 0000, encoding: 29, command: 0A, value: B508
dev:142025-04-03 09:44:45.350 AMinfoAqara Test Sensor pressure is 98.3kPa
Beta Hub is a C7 and it did not work with C8 Pro with same version of OS.
I updated Beta hub to 2.4.1.152 and still have the problem.
Let me know if you need anything else.
Tagging @mike.maxwell
What was the last platform version when this device worked for temperature?
Currently working on 2.4.0.151 in my production environment
I concur! Update on C7 from 2.4.0.151 to 2.4.1.151 has broken temperature on these sensors.
Both mine were the same, I just reinstalled them and they're fine now
Have you used the inbuilt driver again? Or is it possible youve re-paired and picked up a community driver you used before?
I've re-paired two of mine, and the same issue persists - it has not been fixed.
what was the last platform version these reported correctly on?
As said before - 2.4.0.151 for me. I am not on the Beta, so that was the last available version before the jump to 2.4.1.151 when it stopped working.
Yup, found the bug, will be fixed in the next platform version
Just looked and they both dropped off around 3-4 hours later
Just updating as I type
Confirmed fixed. Thanks @mike.maxwell :partying_face:
This topic was automatically closed 90 days after the last reply. New replies are no longer allowed.
