Either copying or cutting and pasting this:
becomes this:
becomes this:
There's probably a couple of details someone who can help may want:
What version of RM are you using, the current version (5.1?) or an earlier version?
What platform version are you running?
What is the background of the contact sensor in the condition? Is it a virtual sensor, what driver are you using, etc.
I just verified this behavior in the latest firmware version of HE. It is probably related to the issue I have with HE. If you create a condition inside a IF and then delete the IF it also deletes the condition. If you used that condition elsewhere then it will be deleted in those IFs as well.
There is a thread about this and if I find it I will provide a link. Not sure this is something they are going to change as it makes modifying existing rules a bit tricky. A few times after creating a simple conditional I realized I really needed to use a normal IF. So I created the IF using the condition I created in the simple conditional, only to realize after deleting the simple conditional that the condition was now gone from the new IF as well.
This is a known and reported bug. Fixed in the next release.
