Bug report: Motion Lighting affects levels set via dashboard tile across multiple dimmers
I've got dimmers (Lutron Caseta devices) in two separate rooms assigned to the same motion lighting rules. The rules are only active between {Sunset -30} - Midnight, Midnight-{Sunrise -30}, {Sunrise -30} - {Sunrise +30}.
The motion lighting rules work fine.
Adjusting the level of either light from the physical switch works fine -- the lights dim independently.
I've also got a dashboard with separate tiles for each dimmer.
Adjusting light levels of either dimmer through the dashboard, during the day (when motion lighting rules should not be active) synchronizes both dimmers under some circumstances.
Here are a few examples, each instance starting with both dimmers off.
Timepoint	Light A			Light B			Behavior
0		   Off,  @ x        Off, dimmer @ y
1		   dimmer to @ 75				    A turns on @ 75, no effect on B
2					          turned on @ 60   A synchronized to 60
3		   lower to 50					       no effect on B
1		dimmer to @ 100				    A turns on @ 100, no effct on B
2					          turned on @ 100
3		lower to 50					          B sync'ed to 50
4		raise to 75					          no effect on B
5		lower to 40 					          no effect on B
6					          lower to 20		no effect on A
1		   dimmer to @ 55					    B synced -- turns on @ 55
1					          turned on @ 55		no effect on A
2					          raised to 60		   A sync'ed -- turns on @ 60
0		    Off,  @ 70      Off, dimmer @ 30
1		    dimmer to 55				            B synced -- turns on @ 55
0		Off,  @ 70	        Off,  @ 30
1					           dimmer to 25	        A synced -- turns on @ 25
2		raise to 55					                  no effect on B
3					           raise to 80	           no effect on A
Turning either light on via the dashboard switch (the bulb icon) without changing the dimmer level has no effect on the other light.
Changing the Motion Lighting rules to specify only a single dimmer resolves the problem on the dashboard.
