[bug report] HSM re-arm doesn’t work in RM
I’ve tried every way imaginable to re-arm all HSM rules in RM, but you cannot unless you physically go into HSM at the bottom and hit the re-arm button. Is this a bug in the software? I’ve even clicked on the run actions button within this rule and it will not work. I’ve posted this in the FB group and others have tested and confirmed this bug. Rick G suggested to post here to get attention to VICTOR to quickly fix.
Here is a screen shot of rule that doesn’t work. Evelin if I push the “run actions” button within this rule it does not re-arm all HSM rules. It also shows nothing happening in the logs.
You don't have logging enabled for this rule. Please enable all logging, then post the logs for when you trigger the rule.
Screenshot 2024-10-25 at 10.17.18 AM
Also, please show the setup page for HSM.
Do you realize the "HSM Rules" means HSM Custom Rules, not the main elements of HSM itself? HSM can be armed for Intrusion, Smoke, Water, etc., as well as have Custom Rules. The command you are giving is for the Custom Rules. Do you even have any? Need to see the HSM setup page.
@bertabcd1234 Is the documentation clear about this for the RM side?
It is now. :slight_smile:
I did enable logging, shows nothing. Here is a screenshot I took shortly after initiating the rule. It never showed up as any command in logs. The button commanded this action and it did record its action in log.
Here is a log from the rule. Running the rule manually or by pushing button does not re-arm HSM.
So arm all HSM rules doesn't include water and smoke?
So I have water and smoke setup, as well as home and away intrusion. I cannot re-arm water some
Via this rule discussed. Many in the facebook group have recreated this and found this same bug.
No.
So should I abandon the water and smoke HSM rules and re-create them as custom rules in order to do this? There is no other way that works to re-arm except to go into HSM manually and re-arm. Seems a bit counter-productive.:roll_eyes:. After
I find and disable alert for water leak, want an easy way to re-arm instead of fumbling through the app to turn back on.
Arm All Rules arms Custom Rules, and only Custom Rules.
You're going to have to do something obviously. There is a sequence that can be done in the HSM UI, or using RM, where Disarm All is followed by Disarm. The Disarm step re-arms Water and Smoke, and would look like this in the HSM UI:
RM supports all of the needed commands:
Why do you have more choices within your selection than I do?
I guess Im going to close this out and just move both water and smoke HSM into a custom HSM rule. Not going to work as needed for me.
