The Generic Component RGBW Light Effects device passes a null effectnumber to the parent driver when the setEffect command is executed with any value.
The following code snippet produces the below log output
void componentSetEffect(cd, effectnumber) {
log.debug "componentSetEffect effectnumber=$effectnumber"}
componentSetEffect effectnumber=null
There is also a spelling bug in the same child driver...
componentSetPrevoiusEffect is called instead of componentSetPreviousEffect
both of these will be fixed in a forth coming 2.2.8 hot fix
Think I found another bug in the same component... setLevel logs to debug as null even though the level is sent to the Parent correctly - might be worth fixing that too
system
Closed
September 24, 2022, 10:55am
5
