[BUG] [2.4.0.151] - In Rule Machine Actions, when deleting multiple Actions
In Rule Actions, if you use the multi-item delete option and select any actions, and then decide you don't want to delete these actions and hit the "Cancel" button, it deletes the items anyway instead of cancelling.
Thanks for the report. For now the solution for this is going to be removal of many lower level Cancel buttons, as they don’t actually cancel the selection. As it stands right now, it isn’t possible to actually cancel an input selection. Such a selection can be reversed / undone / deselected, but not canceled. Actually adding Cancel for input selections would be a sizable undertaking. I can’t say if or when that might happen, but removing inop Cancels such as this one will be done soon.
