Are there any UK HE users also using HD+ as their dashboard?
Now that BST is upon us I am having issues with some times being displayed minus 1 hour. For example, a hub variable is shown by the device list as '9999-99-99T10:12:21.021+0100' but is displayed by HD+ as 09:12 am. If I edit the time in HD+ to 11:12 am the HE device display now shows '9999-99-99T11:12:21.021+0000' and HD+ now shows it as 11:12 am.
If I then use RM to set the hub variable to current time the HE device displays as '9999-99-99T10:21:18.018+0100' and HD+ displays as 09:21 am.
So it is clearly to do with the +xxxx portion of the time.
I will need to raise the issue with the HD+ developer but clearly a change would impact other users, so would appreciate some feedback from UK users.
In order to troubleshoot this issue, you may want to try adjusting your time zone settings in both HE and HD+ to ensure that they are properly synced. You may also want to check for any updates or patches to HD+ that may address this issue, or reach out to the developer for further assistance.
I have checked HE and time is set correctly to BST. There is no setting in HD+ for time zone so I guess that it takes it from Android which is also set to BST.
