If you look up about 10 posts, the maintainer of the Hubitat code also understands the fix. That isn't the issue.
The issue is that the security on the hub doesn't allow the method needed to fix this. Unless Hubitat is willing to change the item outlined in post 466 above.
If someone gets it working on ST we can probably get it working here too. I suspect, however, when they give it a try they’ll hit the same wall I did. I think the ST author is wrong and won’t be able to make it work. But I’d be happy to be wrong!
I’ve been following some of the other integration projects, and a few people have reported intermittent connection issues. It seems to be related to maintenance MyQ is continuing to do. Either way, it has not gotten in my way. Progress is happening, but it’s slow going. We’ll get there.
My question is why even bother? For 75.00 I was able to completely forget about MyQ and the repeated outages because they keep trying to put us all behind their paywall after we have spent good money to buy their products, not to mention I have more control of my doors now and it is completely local.
Let's say you can hold your breath long enough to see this current conundrum through (assuming a fix is even possible this time)... How long until you're back in this same spot yet again when MyQ suddenly decides to mess around more with their cloud? If this pattern hasn't gotten old for you yet, it will. Do yourself a favor and get off that merry-go-round
I was pretty bummed about this whole ordeal as I had used it a lot, but thankfully for me, it was virtually free to migrate to a local solution. I had an unused garage door opener and already had a ZEN16 on that side of the house that I was only using 1 set of contacts for, so all in, the process took about an hour. It would have taken less time if I hadn't used some leftover telephone wire for the project - I needed 4 conductors and the spool was just sitting there collecting dust, so it seemed ideal. However, it kept breaking when I would attach it to the ZEN16 terminals because it was so thin (and a complete PITA to strip since it's not really designed for that).
Yes, I'm thinking the same on MyQ Lite app for Hubitat. Time to move on since I doubt even if he gets it working using another cloud service there won't be issues eventual. Better to get in working locally.
I ordered the Garadget Security+ 2.0 Wired Dry Contact Adapter and the ZEN16 relay yesterday.
I never really use the MyQ app on my Android phone but when I tried using it today, I notice now that I have to click once to get the open or close icon.
Then I have to click it a 2nd time to execute the open or close command.
This might been changed in an older update, but I remember only to have to click the garage icon one time to open or close it.
Hubitat has me spoiled.
Believe 3500 is just Security+ meaning that you can just short/briefly connect the 2 opener wires to activate the opener. Give that a try to confirm. If so you won’t need this 2.0 device and could use a zen16/17 directly to open the door or any dry contact relay. I personally went with a Zigbee one.
But we should take this conversation to this thread:
If Hubitat is willing/able to add support for the feature I need I can definitely get this working rather quickly. If they don't, not too much I can do though. Unfortunately I haven't heard anything other than @tomw mentioning @gopher.ny would take a look in response do a different integration stalled by this. So we'll see. Definitely WAY better likelihood that HE adds the feature vs ST
