Do I need to fill in the AND "secondary check" if I'm selecting Logging Level: Error
It seems that it's not working if I just want to see errors in the logs. It appears as if I have to select every keyword in addition to the "error" selection. Is this correct?
Will this work: (L) - if (error) and (- or - or - or -) but not (- or -)
I reboot my hubs nightly. And it seems that the device disconnects from the log info during the reboot. At least, the device says: disconnected. and doesnt pick up errors in logs. Should it auto connect? It hasnt for me that last 2 nights. I'm on latest version.
I'm seeing the same: not notifications every (even though there are errors in the logs) with "(L) - if (error) and (- or - or - or -) but not (- or -)", did you end up finding a solution? Thx!
