I have a couple of tiles in a dashboard that pull images (weather updates). The images get updated from time to time (about once an hour) and I have the tiles refresh every hour or so to get a fresh image (using the image tiles refresh setting). Once in a while, the image isn't pulled correctly and it looks like a broken image in the dashboard (see the outline but no image). Refreshing the whole page pulls new images and everything is fine. I lowered the refresh rate to help combat this (the amount of time a broken image is shown), but I am wondering if I can look at logs or something else to figure out why the images aren't loading correctly (maybe the remote source returns a 5xx error) or trigger on an error and have it re-pull the image automatically.
What are you running the dashboards on and in? Like iPad; Safari or Android; Chrome. I use a kiosk browser and have it do a full page refresh as well. I've also had the issue you speak of, but not sure if it gets logged. Perhaps if it did, we could use the error to trigger a secondary delayed refresh? Following to see where this goes.
Chrome browser running on a Windows 10 AIO mounted to the wall. Network is over wifi. It only happens when pulling images off the Internet. The other local images load fine.
