I am currently using RM to alert me when there is a water leak detected. I have an activation rule that changes the mode to water detected mode which then triggers a rule to send notifications to echo devices on repeat. The issue is that because I'm not using the water detected as a trigger in the echo notification rule, it's just stating my hub's name since that's the device that's triggering it and not the actual water leak device from the other rule that activated the trigger rule. Is it possible to connect to rules to see each others variables/devices?
Or should I just make the repeater trigger also utilize water sensor trigger and call it a day?
Ahhh okay. I was confused because you used test-O as your initial hub variable value for the screenshot. Then it appeared as a trigger device in your screenshot for initial RM, which I couldn't replicate in the RM options.
