Yes. I believe the size is A-21 vs standard A-19
I decided to try a different Wiz 1600 lumen A21 bulb. I'm observing the same behavior as last fall. It's blazingly bright in Daylight mode, but much dimmer in Warm white mode. Since my wife prefers warm white, I guess that's it for Wiz. Is that the rest of you have noted about Wiz bulbs? I think that's the difference between them and Kasa and especially Lifx. The others are still bright when in Warm white mode.
I think it depends on how warm you go I generally have kept mone above 2700 even when looking for warm white. When i push them all the way to 2200k which ia their lowest color temp they are certainly dimmer. It is also woth noting not all color bulbs are the same for the color temps. Some devices get more redish then yellow and such. Have you looked at Govee bulbs. Their Lyra and Cylinder lamps get very bright on the warm white side.
That said i think the highest lumen they commet to for a regular bulb is 1200 so maybe not upt to what you are looking for.
I decided to put in a Kasa KL-135. At 2700K it's much brighter than the Wiz. At "Daylight" (5000K?) the Wiz is super bright but I'd be kicked out of the house...
Not sure if you're settled on this question or not, but I have a house full of Wiz and just saw for the first time (and immediately purchased) a 150W-equiv 2550 lumen Wiz RGBW bulb at Home Depot yesterday. They're not on Amazon, and when I googled around the only place I saw it was Home Depot, but it's there and I put one in yesterday. It's awesome.
