You might want to mention the country you live in because all the suggestions in this thread won't work for you unless they can be shipped to where you live.
Philips Hue has two bulbs that are 1600 lumens. One is white and the other is both white and color capable. Note that both are A21, which is a little larger than the more common A19 size.
To control with Hubitat, you need a Hue Bridge. Hubitat has native integration with the Hue Bridge that works very well in my experience.
Israel, but I can order from online stores.
yeah, it seems like the only solution. It's a shame that no other brands are offering the same bulb at a reasonable price.
I bought a few of the Hue rgbw 100W equivalent bulbs. They are very bright as advertised, but will also dim very low as I’ve come to expect from Hue. It was about time they put out a bright bulb.
In terms of the base, any idea if an A21 bulb is equal to E27?
E26 and E27 refer to the Edison base (the portion that screws into the socket). A19 and A21 refer to the bulb size.
An A21 bulb can have an E27 base.
If you meant to compare A19 and A21, here’s a link explaining the differences…
Yeah, just read about it. Thanks
