I have several of these Bosch detectors and am happy with their performance except when the batteries die with no notice from device watchdog because they are always reporting 100% battery level. I measured the voltage on my batteries, turned on debug logging for the devices and dug into the battery reports. lastBattery is the epoch timestamp of the last battery report, not the measured level.
These detectors are measuring only part of their battery pack. The Hubitat driver is reading the correct value but not interpreting it right, Here are my results:
ISW-ZDL1-WP11G with batteries that measure 1.22v
descMap: [raw:73920500010820002030, dni:7392, endpoint:05, cluster:0001, size:08, attrId:0020, encoding:20, command:0A, value:30, clusterInt:1, attrInt:32]
30 hex is 48 decimal, which is 4.8v (four batteries at 1.22v)
ISW-ZPR1-WP13 with batteries that measure 1.43v
descMap: [raw:CA65050001082000201D, dni:CA65, endpoint:05, cluster:0001, size:08, attrId:0020, encoding:20, command:0A, value:1D, clusterInt:1, attrInt:32]
1D hex is 29 decimal which is 2.9v (two batteries at 1.43v)
I made a percentage range based on observed performance of my detectors. The detectors work but range starts to be reduced at 1.2v per cell, I am calling 1.1v zero percent bottom of the range. Using 1.6v per cell for new cells. These numbers fall in line with this reference and give nice percentages.
https://en.wikipedia.org/wiki/Alkaline_battery
The ISW-ZDL1-WP11G has 6 batteries and sends the voltage for 4, use min=44, max=64
The ISW-ZPR1-WP13 has 4 batteries and sends the voltage for 2, use min=22, max=32
Percent capacity = (value-min)/(max-min)*100
This is what I get for percentages using this formula for the cases I listed above:
Model: ISW-ZDL1-WP11G
Value: 48
Max: 44
Min: 64
Capacity: 20%
Model: ISW-ZPR1-WP13
Value: 29
Max: 22
Min: 32
Capacity: 70%
Can someone at Hubitat please correct the math on the battery reading?
