Hi all - seeing conflicting info in my searches and wanted to validate my use of Private Boolean. Will this work where I am setting a wait time, then setting PB to true within the same rule? I’m trying to make it so this only runs once a day, in the morning. Or do I have to reset the PB to true from a different rule? Thanks in advance for any feedback!
That should work. You can set Private Boolean from the same rule (as long as you have a way to make it do that--you do, since the "Wait" will effectively schedule this action for the future) or a different rule (if you can find a way for it to make sense, in your case maybe a trigger of 9:01 AM). But, again, as you have it now should work!
Personally, I also always like to put "Set Private Boolean False" for things like this first in the rule; that way, if you get another trigger event, it's more likely to have already been set and prevent re-triggering (and defeating the purpose of including it). But your first two actions should happen pretty fast, so this isn't probably something I'd worry about here.
That will work. Another option would be to Wait for event certain time 8:00 AM.
My preference is to make the first action Set PB to False but I don't think it necessary.
Great, thank you!
Thanks much for validating!
