Thanks for adding native Bond support! I have a feature request for the new Bond app. When paired with Somfy window shades there are three action buttons that can be pressed from Bond: open, close and a preset position called the “my button”.
The “my button” can also be used while the shades are moving to tell the Somfy motor to stop moving and keep the shades at their current position.
Requests:
- Add a Somfy Window Shade driver.
- Add a “my button” command on that new driver.
- Wire up the slider positions of 0% to the close action, 100% to the open action and 50% to the “my button. Wiring up 50% to the “my button” allows Alexa to trigger that action even though Alexa only sends position levels 0-100% when controlling window shades. The current integration does not work with Alexa at all, I think because the 0-100% position slider isn’t wired up in Hubitat.
