Bond hub and Harbor Breeze fans
The house I am buying has several Harbor Breeze fans that seem to be work well enough. They're all fan/light combos that are controlled by remote. Does anyone know if the fans are compatible with the Bond hub? Or do I have to swap the controller out?
They should be supported by bond. The frequency of the remote falls within the range that the Bond hub supports.
I'm using a bond hub for a couple of fans and have been very happy. You won't be able to use the remotes though as everything has to go through the bond since it's one way communication.
Planning on using Pico.
