I made a bluetooth sensor that reports to Hubitat. Here's the Github repo. Please note that iPhone devices do not work with this as Apple disables any sort of scanning unless it is running in the foreground. This also happens to be the reason I will likely not keep this repository updated (my partner loves her iPhones). For those who use Androids, please let me know what you think! The main program to run this is below. Please note that I'm also not a python programmer. I used python because I was planning to run this on a raspberry pi.
import bluetooth
import datetime
import json
from peewee import *
import requests
import sched
import sys
import time
from datetime import timedelta
from sqlite3 import Error
db = SqliteDatabase("./scanner-status.db", pragmas={'foreign_keys': 1})
s = sched.scheduler(time.time, time.sleep)
class BaseModel(Model):
class Meta:
database = db
class Hubitat(BaseModel):
id = AutoField()
hubitat_ip = CharField()
cloud_auth = CharField(null=True)
maker_api = CharField()
access_token = CharField()
class Device(BaseModel):
device_id = CharField(primary_key=True)
mac_address = CharField()
name = CharField()
class Status(BaseModel):
id = AutoField()
device = ForeignKeyField(Device, backref='statuses', unique=True)
last_update = DateTimeField(default=datetime.datetime.now)
def main():
db.connect()
db.create_tables([Hubitat, Device, Status])
hubitat = Hubitat.create(
hubitat_ip="", # hubitat IP
cloud_auth="", # hubitat cloud auth string. Leave blank if using local connection
maker_api="", # hubitat maker api
access_token="" # hubitat access token. found after ?access_token
if hubitat.cloud_auth is None and hubitat.cloud_auth.strip() != "":
url = hubitat.hubitat_ip + "/apps/api/" + hubitat.maker_api + \
"/devices/all?access_token=" + hubitat.access_token
else:
url = hubitat.hubitat_ip + "/api/" + hubitat.cloud_auth + "/apps/" + \
hubitat.maker_api + "/devices/all?access_token=" + hubitat.access_token
data = send_request(url)
now = datetime.datetime.now()
for device in data:
id = device.get("id")
device_query = Device.select().where(Device.device_id == id)
if "type" in device:
if device.get("type") == "Virtual Phone Presence Plus" and not device_query.exists():
Device.create(
device_id=id,
mac_address=device.get("attributes", {}).get("BluetoothMacAddress"),
name=device.get("name")
Status.create(
device_id=device.get("id"),
last_update=now
print (device.get("name"), "was inserted into db")
nearby_devices = bluetooth.discover_devices()
for device in Device.select(Device, Status).join(Status, attr='status'):
if device.mac_address.upper().strip() in nearby_devices:
is_nearby = True
else:
is_nearby = False
cloud_status = get_cloud_status(device.device_id, hubitat)
if is_nearby:
device.status.last_update = str(now)
device.save()
print (device.status.last_update)
if is_nearby != cloud_status:
if is_nearby:
print("turning " + device.name + " on.")
if hubitat.cloud_auth is None or hubitat.cloud_auth.strip() == "":
new_url = hubitat.hubitat_ip + "/apps/api/" + hubitat.maker_api + "/devices/" + \
device.device_id + "/on?access_token=" + hubitat.access_token
else:
new_url = hubitat.hubitat_ip + "/api/" + hubitat.cloud_auth + "/apps/" + \
hubitat.maker_api + "/devices/" + device.device_id + "/on/?access_token=" + hubitat.access_token
print ("sending request: " + new_url)
send_request(new_url)
elif is_five_min_ago_plus(device.device_id):
print("turning " + device.name + " off.")
new_url = hubitat.hubitat_ip + "/api/" + hubitat.cloud_auth + "/apps/" + hubitat.maker_api + \
"/devices/" + device.device_id + "/off/?access_token=" + hubitat.access_token
else:
hubitat.maker_api + "/devices/" + device.device_id + \
db.close()
print ("connection to db closed")
s.enter(30, 1, main())
# Sends request to Hubitat and returns response
def send_request(url):
try:
r = requests.get(url)
except requests.exceptions.RequestException as e:
print(e)
print ("Hubitat update failed. Trying again")
send_request(url)
if not r.status_code == requests.codes.ok:
print(now), "Hubitat update failed with status code ", r.status_code
if int(r.status_code) == '500':
print(now), "Is this really a Virutal Switch?"
else:
return r.json()
# Gets the current status of device from Hubitat
def get_cloud_status(device_id, hubitat):
device_id + "?access_token=" + hubitat.access_token
else:
hubitat.maker_api + "/devices/" + device_id + "?access_token=" + hubitat.access_token
value = data.get('attributes', {})[2].get('currentValue')
return value
# Checks if timestamp is less than 5 minutes ago
def is_five_min_ago_plus(device_id):
timestamp = Status.get(Status.device_id == device_id).last_update
five_min_ago = datetime.datetime.now() - datetime.timedelta(minutes=-5)
return timestamp >= five_min_ago
if __name__ == '__main__':
main()
