Bluesound Driver
I want to share Bluesound Driver. You are free to modify it. I made this Helped by @tomw . Thank you so much for your help.
metadata
    definition(name: "Bluesound Node2i", namespace: "putudhony88", author: "tomw", importUrl: "")
        capability "AudioVolume"
        capability "Initialize"
        capability "MediaInputSource"
        capability "Refresh"
        capability "MusicPlayer"
        command "executeCommand", ["command"]
        command "repeat"
        command "shuffle"
        command "bluetooth"
        command "hdmi"
        command "spotify"
        command "analog"
        command "preset1"
        command "preset2"
        command "preset3"
        command "preset4"
        command "preset5"
        command "preset6"
        command "addZoneSlave", ["slaveIP"]
        command "removeZoneSlave", ["slaveIP"]
        attribute "trackArt", "string"
        attribute "trackAlbum", "string"
        attribute "trackArtist", "string"
        attribute "trackTitle", "string"
preferences
    section
        input "IP_address", "text", title: "IP address of Bluesound unit", required: true
        input "refreshInterval", "number", title: "Polling refresh interval in seconds", defaultValue: 60
        input name: "logEnable", type: "bool", title: "Enable debug logging", defaultValue: true
def logDebug(msg)
    if (logEnable)
        log.debug(msg)
def installed()
    sendEvent(name: "supportedInputs", value: '{"HDMI", "Bluetooth", "Spotify"}')
    initialize()
def initialize()
    refresh()
def refresh()
    unschedule(refresh)
    def status = httpGetExec("Status")
    if(status)
        events = [[:]]
        events += [name: "volume", value: status.volume.toInteger()]
        events += [name: "mute", value: (status.mute.toInteger() == 1) ? "muted" : "unmuted"]
        events += [name: "status", value: status.state]
        events += [name: "trackData", value: status.streamUrl]
        events += [name: "trackDescription", value: "${status.title1} - ${status.artist} - ${status.album}"]
//      events += [name: "trackArt", value:"<img src=\"${status.currentImage}\">"]
        events += [name: "trackArt", value: status.image]
        events += [name: "trackArtist", value: status.artist]
        events += [name: "trackAlbum", value: status.album]
        events += [name: "trackTitle", value: status.title1]
        switch(status.inputId)
            case "input4":
                events += [name: "MediaInputSource", value: "HDMI"]
                break
            case "Spotify":
                events += [name: "MediaInputSource", value: "Spotify"]
                break
            case "input2":
                events += [name: "MediaInputSource", value: "Bluetooth"]
                break
            case "input0":
                events += [name: "MediaInputSource", value: "Analog"]
                break
        events.each
            sendEvent(it)
    runIn(refreshInterval ?: 60, refresh)
def updated()
    installed()
def uninstalled()
    unschedule()
def play()
    executeCommand("Play")
def pause()
    executeCommand("Pause")
def stop()
    executeCommand("Stop")
def nextTrack()
    executeCommand("Skip")
def previousTrack()
    executeCommand("Back")
def mute()
    executeCommand("Volume?mute=1")
def unmute()
    executeCommand("Volume?mute=0")
def setVolume(volumelevel)
    logDebug("setting volume to: $volumelevel")
    vol = volumelevel.toInteger()
    vol = (vol < 0) ? 0 : (vol > 100) ? 100 : vol
    executeCommand("Volume?level=${vol.toString()}&tell_slaves=off")
def volumeDown()
    executeCommand("Volume?db=-1")
def volumeUp()
    executeCommand("Volume?db=1")
def playTrack(trackuri)
    executeCommand("Play:${trackuri}")
def restoreTrack(trackuri)
    playTrack(trackuri)
def resumeTrack(trackuri)
    playTrack(trackuri)
def repeat()
    executeCommand("Repeat?state=1")
def shuffle()
    executeCommand("Shuffle?state=1")
def bluetooth()
    executeCommand("Play?url=Capture%3Abluez%3Abluetooth")
def analog()
    executeCommand("Play?inputType=spdif&index=1")
def hdmi()
    executeCommand("Play?url=Capture%3Ahw%3A2%2C0%2F1%2F25%2F2%2Finput4")
def spotify()
    executeCommand("Play?url=Spotify%3Aplay")
def addZoneSlave(slaveIP)
    executeCommand("AddSlave?slave=${slaveIP.toString()}&port=11000")
def removeZoneSlave(slaveIP)
    executeCommand("RemoveSlave?slave=${slaveIP.toString()}&port=11000")
def setInputSource(inputName)
    switch(inputName)
        case "HDMI":
            hdmi ()
            break
        case "Spotify":
            spotify()
            break
        case "Bluetooth":
            bluetooth()
            break
    sendEvent(name: "mediaInputSource", value: status.service)
def preset1()
    executeCommand("Preset?id=1")
def preset2()
    executeCommand("Preset?id=2")
def preset3()
    executeCommand("Preset?id=3")
def preset4()
    executeCommand("Preset?id=4")
def preset5()
    executeCommand("Preset?id=5")
def preset6()
    executeCommand("Preset?id=6")
def scaleBluesoundToPercent(volumeLevel)
    def percVol = ((volumeLevel.toInteger() + 90) * 100/10).toInteger()
    percVol = (percVol >= 0) ? ((percVol <=100) ? percVol : 100) : 0
    return percVol
def scalePercentToBluesound(volumeLevel)
    def neetsVol = (volumeLevel.toInteger() * 10/100).toInteger() - 90
    neetsVol = (neetsVol >= -90) ? ((neetsVol <= 0) ? neetsVol : 0) : -90
    return neetsVol
def executeCommand(command, doRefresh = true)
    res = httpGetExec(command)
    if((null != res) && doRefresh)
        runInMillis(100, refresh)
    return res
def getBaseURI()
    return "http://" + IP_address + ":11000/"
def httpGetExec(suffix)
    logDebug("httpGetExec(${suffix})")
    try
	    def result
        def getString = getBaseURI() + suffix
        httpGet(getString.replaceAll(' ', '%20'))
        { resp ->
            if (resp.data)
                logDebug("resp.data = ${resp.data}")
                result = resp.data
	        return result
    catch (Exception e)
        logDebug("httpGetExec() failed: ${e.message}")
Has anyone had success using new EZ Dashboard? With old one it works well.
hiya, are you still using this, im just trying to get mine to work but having no luck ,thanks
