I have a Get action that used to work in the old Rules machine. Since updating all my rules using the new RM, this action no longer works to change my Blue Iris profile.
Send GET to: http://xxx.xxx.xxx.xxx:xxxxx/admin?profile=1&lock=2&user=xxx&pw=xxxx
I need to have BI change a profile when this command is sent. Any ideas why this does not work now?
Did the IP address for the PC running Blue Iris change?
I got it figured out now.
It was a config issue with BI profiles configs. HE was sending the profile changes fine. BI profile did change, until a camera tripped. Then BI would to go BACK to the default profile, so it never held on a profile change made by HE.
The "Until triggered" box in BI was checked causing this problem.
Hello,
I'm trying to get this working on my Blue Iris to change profiles like you have set up.
I paste this in Google Chrome "http://xxx.xxx.xxx.xxx:xxxxx/admin?profile=1&lock=2&user=xxx&pw=xxxx"
It keeps showing this "Authorization required"
Blue Iris Logs show message is received.
I have a user setup in Blue Iris with what looks like the right settings
Any help would be greatly appreciated.
Got it working by just replacing the X's.
Thanks for posting the Info.
Now on to setting up different profiles.
I was getting tired of getting multiple text messages while I walked in my driveway.
@moderators please close this thread since the issue is resolved, thanks.
