BlitzWolf BW-SPH13 Zigbee 3.0 With HE?
I have the same problem with the generic drover. Since it reports the power, but does not update by itself, is there a way to access this driver to see if by making any changes we can solve the issue? regards
You can try [BETA] Tuya Zigbee Metering Plug
@kkossev I will try that, also for the last couple of months the "Generic Zigbee Outlet" reporting works fine.
If your BlitzWolf plug is automatically reporting the power and energy (without the need to be polled), then there is no need to switch the drivers.
If the application version is 41, then the plug will report power/energy just fine using the inbuilt generic Zigbee Outlet driver.
However if the application version is 45 (or newer), must probably the plug will require polling.
