So there was a couple of power outages last night and a couple of z-wave devices died. I removed the device and install replacement ones and all was fine until i start a z-wave repair.
This happened.... z-wave setting page is now blank. I can still control the devices via the dashboard.
goto settings>>backup and restore. Click the download button at the bottom and save it to your pc.
go to yourhubip:8081 and then soft reset. Upon reboot restore the database you downloaded to your pc. After restoration, shutdown from the settings menu. Unplug power (at the wall not the hub) for 5 mins then power back up.
Do the power thing I outlined and see if it works, otherwise you'll have to restore from yesterday's backup and re pair the 2 devices you had just done. (make sure you exclude them first so there aren't any ghosts in your database.
Also, I do have a ghost device due to a dead inovelli switch. How do I get rid of that? Is the PC SW controller and the external zwave stick the only way to remove ghosts now?
make sure no power is to that switch. Click refresh on that line until the remove button appears, then remove it. Also have you updated to the latest z-wave stack?
Yup.. latest stack. I tried the remove button a few times already and it's still there.
And this switch died too due to the power failures. It keeps reporting physical switch ON. Tried excluding it but wouldn't work at all. Me thing it's a gonner.
