If I close the app in iOS, and restart the app, I often just get an empty blank screen. I tried rebooting the phone, doesn’t help, still blank screen.
This means I have to reinstall the app a few times a day.
So, you are hitting the home button on your ios device and instead of getting your home screen you are getting a blnak screen? When you say "close the app" what are you doing?
I turned location services off again, but background is still on.
Seems to be working still.
So I think it’s the background service, which must be on.
Edit:
Added my wife’s phone again, watdoyouknow: blank screen on her phone.
Background was on, but location was off (set to only when using the app)
When set to always the app started again.
Ah, yeah, you should have them turned on for ‘presence’ to function.
The Ap is working great on mine and my wife’s iPhone.
No need to change any settings.
Mainly for notifications and dashboard when underway/not at home.
I have used other push systems like pushover/telegram with Domoticz, which I don’t like.
I have a shortcut on my homescreen already, which I use at home when needed.
But there is an Hubitat app, I should be able to use it without location. Why are the dashboards in the app if not intended for use?
For location services there are other options too, like life360, why use the app?
Everyone uses the app for their own use case.
I’m not trying to be a pain, but just explaining.
Edit:
It all seems to work now with geofence turned off. And the services in phone settings on.
Right, it should be able to work with location services turned off (except geolocation, LOL). Sounds like background app refresh may have been the issue?
Edit: I may have mis-read. You still need to have location services enabled for the app to function at all? Or background app refresh?
