C-4 on 2.3.5.145 Sits there for a while doing nothing then returns a blank page.
Also zigbee Graphical view does not seem to be working.
Tagging @gopher.ny @dandanache
Experiencing the same issue on my C7 with latest software release, zigbee routing details are blank.
Rolled back to previous software and it is fine.
Just received a notification that Zigbee was turned off and back on. Have not seen that for a very long time. Falling back.
Can you PM me your hub's id? I'll take a look at the engineering logs.
For built-in Zigbee graph, just tag me, it's not the same as the app.
Same with mine, everything is working but the Zigbee Network Graph (beta) is blank. The devices are counting up though, I assume that's when they are reporting back it adds them to the counter.
The z-wave Network Graph (beta) works fine.
There is also a repeatable error/message on the Zigbee Network Graph (beta) page - when i click on the ZigBee Network Graph (beta) it displays nothing as per arnb screenshot, then when I click on one of the menus down the left hand side I get a message that says:
{hubitats ip address} Says failed to fetch
I click ok and it takes me back to settings.
There is an issue for Zigbee graph on C7 hubs and earlier. Same issue affects /hub/zigbee/getChildAndRouteInfo endpoint.
the .146 update fixed the issue. Thanks
