Looking for open/close sensors in black. Should be wireless, top of door style. So far I am only finding white ones. Suggestions?
rattle can
Yeah as @velvetfoot suggests, just paint them. I use Plastikote acrylic paint for stuff like that - ceiling speaker grills, intruder alarm PIR's and contacts or anything that's yellowed due to UV I've used white. It's touch dry and ready for a second coat in 10 minutes.
Buy a can of Krylon Fusion.
Get an Aerotec sensor that fits in the door -- Aeotec Recessed Door Sensor 7 Then paint the magnet portion.
Definitely spray paint! I haven't done it yet, but I plan on doing this to all my sensors. Look up critter spray. It's an attachment for any mason jar. It's not the best spray quality (like I wouldn't use it to spray paint furniture/doors with it), but it's a lot easier to clean and use than a typical paint sprayer and is perfect for quick jobs like spray painting vent covers or these sensors. I like matching colors exactly and this is a quick easy way to do it with paint you already have.
Any made for plastic spray paint will work. Krylon, Rustolium etc... Just make sure you prep it right. I would recommend using rubbing alchohol prior to spraying as it will help clean up any oils on it as well as most dirt.
I use one of these on a stained wood door.
I just bought three different zigbee black contact sensors.
All of them work fine,
One is smaller but uses a button battery which I suspect life will be shorter.
https://a.aliexpress.com/_mN9fjUG
https://a.aliexpress.com/_mKgeQne
https://a.aliexpress.com/_mqCK7TE
And yes, they’re much more discreet.
