Here you are my first Hubitat driver: Bitron 902010/32 Thermostat
This thermostat it's very cheap (around 70 Euro) and has also limited capabilities (but I was just needing set heatpoint, then I can configure\schedule everything from Hubitat).
A minor issue is related to reporting status\changes: seems that it doesn't report temperatures and heating state on changes, but just on maxReportTime, so I had to set it to 2 minutes and thermostat reports everything every 2 minutes regardless of changes. For sure it will increase battery consumption, I'll update the topic after few months of usage.
@mike.maxwell after 2.0.5 update, my thermostat stopped reporting temperature correctly.
I don't know if the problem is in driver or it's an incompatibility between that thermostat and new 2.0.5 zigbee changes.
Actually in logs I have this: dev:342019-02-14 09:53:17.752 debugTermostato: Desc Map: [raw:88050102010C0000299006, dni:8805, endpoint:01, cluster:0201, size:0C, attrId:0000, encoding:29, command:01, value:9006]
Previously to convert that value to human readable format I was using this function:
But now seems that it's repoting something weird, for example with value 9006, temperature is 368.7 °C while it should be something around 17 °C
Unfortunately I don't have any values before upgrade, but from events it's clear that something went wrong after the update, previously temperatures were fine.
EDIT: Found it! Driver that I was using as base had a custom override for parseDescriptionAsMap, removed it using the standard HE one and it's working fine.
