That's your hub name . I've checked it is retained , so is that topic present on MQTT when you get that message ? It is on mine
yup - seems to be the OH side. Thanks
For any of you on the Openhab side I have created my own project that is just used to publish Hubitat items into Openhab via the OH homie discovery. This is tailored a bit towards openhab as it doesn't use things like ENUM (which aren't supported in OH homie as of now) and the dimmer values are published as 0:1 so it works with an OH dimmer type. Let me know if interested in checking it out via PM.
Beta 3 available
Dear Kevin and others,
I am trying to discover my Athom Homey devices into Hubitat. But although I know a thing or two about computers, MQTT is all new to me. I have been reading a lot in this forum and on the Homey forum, but so far I haven't achieved success. So I hope you can point me in the right direction. What I did manage so far:
I also installed MQTT explorer and I can see all kinds of info there based on the settings from step 2)
I think I am almost there. Could you give me a tip where to look next?
Regards,
Bert
Very helpful analysis .. thanks...
The homie protocol is the least well supported of the discovery protocols into HE. That is essentially because the documented protocol definition is lacking in definition at this level. However non color lights and switches (dim and onoff) probably work OK.
In the drop down list that is under homie there are no devices discovered (0 of 0) which is not encouraging. Are there onoff and dim devices published by Homey and is the $type payload socket for onoff and light for dim?
Are topics being published 'retained' ? You can test this by disconnecting and then reconnecting MQTT Explorer. If the topics are retained they will re-appear upon connect (do not republish from Homey).
You are not using MQTT Hub custom topics are you ? Also what version of MQTT Hub, Client and Broker are you using ?
If still no clue then can you paste me an image from MQTT Explorer of one of your Homey onoff devices fully expanded and I will try it here.
Next beta offers other options but something is not working right for you in current beta which I would like to ascertain why first.
Hi Kevin,
Thank you for your quick reply. I'll try and answer your questions as best as I can.
Sorry, but I don't understand what you are asking
As mentioned this is my first adventure with MQTT.
I have Aqara motion and temperature sensors in my homey. And Aqara smart switches. Also some 433 mhz KaKu (trust) switches and a few smart plugs from different brands. I am also not sure how to check for "$type payload socket for onoff and light for dim?"
No after doing what you asked only new messaged appear after I reconnect
Not that I am aware of, just started trying this a few days ago.
On my Homey
MQTT Hub v3.4.2 by Harrie de Groot
MQTT Client v3.0.0 by Menno van Grinsven
MQTT Broker v1.0.5 by Menno van Grinsven
Is this at all helpfull ![]()
Regards,
Bert
Thanks Bert
Two issues..
That MQTT topic structure as published by Homey is not homie3 compliant - a lot of topics are missing.
Also the topics/payloads must be published 'retained' or when HE tries to read them they wont exist.
Here is a device originating from Homey as published by the MQTT hub. The full topic path is
homie/louey/davenport
Louey being the name of the Homey and Davenport the name of a dimmable light.
You can see the extra topics like $properties and $type that are essential to discovery. Now it is possible that clearing these topics using the wastebin in MQTT Explorer removed these and that they will re-appear if you ask MQTT Hub to broadcast it's data again (or restart MQTT Hub).
The second issue of the payloads/topics not being 'retained' has to be fixed too though as HE will not see the payloads it requires on the broker. I will take a look on a Homey I have access to here to see why that may be happening (it is wrong).
Can you re-run the MQTT Hub (or broadcast) and see if more topics get sent to the broker and also afterwards disconnect the MQTT Explorer and reconnect and see if they are still there. Do not click the wastebin. If they are there , similar to above can you paste me a $type=socket device and an expanded $type=light device
I was just trying a bit here and there.
The MQTT Discovery Protocols > HE menu is now kind of stuck in the green message: Homie [Checking]. May be I need a little patience now
Let's take this to PM but that's looking good..
The checking wont take too long - maybe a minute - exiting that menu and coming back may show it has finished.
PM sent
Just as an update on this the Athom Homey MQTT Broker v1.0.5 by Menno van Grinsven is only a partial implementation and does NOT support retained messages. A big restriction and this makes it unsuitable for most MQTT usage.
My MQTT app will not work with this broker as it requires the retained feature. I would suggest an external broker like mosquitto for Athom Homey users.
