I am not new to Webcore on Hubitat, but the Package Manager is a new one for me. I just installed it and entered my correct info during the app setup and now am getting this error upon running the app: (I enabled the OAuth):
Error logging in to hub
An error occurred logging into the hub. Please verify your Hub Security username and password.
It's there something wrong with search? I can't find any of the packages I've been looking for in the last few days using search. Listing by tag worked but search did not. A known issue?
Request.
Can we get the info logs turned off like the debug?
2021-04-09 08:42:59.643 infoUpgrading Xiaomi Aqara Mijia Sensors and Switches
app:2232021-04-09 08:42:59.304 infoDownloading Xiaomi Aqara Mijia Sensors and Switches
app:2232021-04-09 08:42:50.653 infoChecking for updates for webCoRE
etc.
It was suggested I post this here - I posted this in a different forum thinking it was the right place... sorry bout that! I posted:
Did a search and don't see any other post about this - I've recently enabled Hubitat Package Manager to do automatic updates. (about 2 weeks ago I believe). Since then I've had some problems and want to try to isolate -
Would it be possible to add another button in the HPM to 'show history'? It doesn't seem possible to use the system logs/event logs to see what has updated and when.
thanks!
Shu
Debug logging is turned on by default I think. Maybe not though. I have it turned on in mine and I don't remember turning it on. So I think it was that way by default, but again I could have forgotten.
I went and looked at the logs from this morning, I have my update time set to 6:00 am. In my case it showed a list of every package I am currently using and it checked for an update. I believe if there was an update to any of the packages it would have listed it there. I don't have auto update turned on though, it just notifies me.
Log sizes are limited so depending on how much logging you have going on you might have to look right after the update check is ran
Can anyone help with the initial steps of getting the Hubitat Package Manager installed? I found the files on github, but what do I do with them? I assume that this is a very simple task and am maybe just overlooking it.
