[Beta] Flow Engine - A visual drag and drop rules engine
@bptworld Here is part of a flow (see pic) and I cannot connect the 2 nodes. I am on Chrome. I also tried on Firefox with the same result. When I click on the right partial circle of the Action node all it does is move the node. Don't know the name of that partial circle.
PIC1
I just uploaded a fix on Github, give it a minute and do a 'Repair'. Don't know if it broke anything else at this point but hopefully all is well. :wink:
edit: I just made the 'Dots' bigger too
I am able to connect tiles. But I don't have a Speech Notification on so I don't know if that was the issue.
I'm not sure what LocK Tiles does as I"m able to move them around independently if I only click on one afterwards and it doesn't seem to lock them from being editable. So please explain what the lock does.
Thanks,
Also, Distribute Horizontally didn't do anything when I either had the Event Trigger, Conditions and either top Action or both Action tiles selected.
As you can see, the Condition tile definitely should have moved.
Thanks. Working fine again.
The locking of the tiles is suppose to make it so you can't drag them or move them by accident. They should be 'locked' in place. But they broke the connections - so I fixed the connections and broke the locks. lol. I'll get them working again soon.
I’m finding it amazing how much you’ve added (and fixed as needed) so fast. I think you are very close.
Once you get this fixed maybe you can revisit the time based ones as I think a lot of routines will use them. Just brainstorming it, maybe checkboxes for the days of the week with an All, Weekends, and Weekdays choices as well.
Times could be trickier as you’ll want a Sunrise and Sunset options, with a +/- Offset field, but also the ability for the enduser to put in a precise time. Maybe for exact times that can be done with an Hour, Minutes, and AM/PM spinners to help avoid syntax errors.
@bptworld So I have seeing a possible issue either in the Delay (kind of doubt) or in the Speech part. The flow trips with the door changing to open and the Delay is tripped by the change in color to it's input. The Delay completes and the flow continues to the Speech. At this time there is no speech output through the speaker. I don't know if it how I have the Speech text configured or not. I tested the speaker manually and it is working correctly.
One other question. Is there currently or will there be a way to have a speech repeat every so often if a condition still presents itself like a door remaining open, it will speak it is still open, until that door is shut.
New drop on Github...
  • fixed the time inputs
  • fixed the notifications
Time for another 'Repair'
Maybe I make a Repeat Node... I'll look into it.
Working fine. Speech is back.
Awesome. The repeat node will be a useful addition. Thanks
@bptworld I was wondering if there is something in the works for adding a trigger that we could select a date or multiple dates to go along with a time for instance, kind of like in the pic below. Thanks
This is the last one for a while. I don't want to overwhelm or upset you. This one is self explained.
Quick update....
  • Added Repeat node - Set max number of times it can repeat. Should follow a normal Delay node.
  • Nodes 'and', 'or' now only have 1 input and 2 outputs - check your Flows! (you can still connect as many devices as you want to the 1 input)
  • Locking is still busted
'Repair'
For some instances of this you can use the Schedule node and enter in your own Cron expression. I like to use Cron Formatter.
No dot shouldn't happen anymore but please let me know if it does!
Just did a repair (4:00 pm EST 07/02/2025) so I believe I'm up to date. (Which, BTW, if you could put what the current version is someplace and for us to see our version just to be sure we are on the current on, it would be helpful).
In any event, when I test a flow I don't see the flow nor do I see the flow was executed.
Screenshot 2025-07-01 at 4.06.35 PM
Fingers are flying today!
  • Finally fixed the node lock/unlock!
  • No more need to open the One app after making changes to a Flow in the Editor! You still have to add new Flows but when editing an existing Flow, all you have to do is save it in the Editor.
'Repair!'
Versioning will start with the Release, too many quick updates in Beta
I've made a lot of changes, will look into test in a bit
Nice addition, man you be the coding master these days!!!
Deleted
Getting down to the last couple of items...
  • Hopefully fixed the Test option
  • Click outside of any node (click the background) to deselect all nodes.
Another 'Repair'
As always let me know how it goes.
