We don't have a driver that will accommodate everything this device offers.
We have drivers that cover temp/motion/humidity and temp/motion/illuminance, but not all 4 together.
Hello.
I also buy this sensor, but I tried all generic drivers, and I can only see motion status. Which driver I should use if I want to use motion+temperature+illumination?
Hue motion sensor drivers have those attributes, not sure if the built in driver will work or not.
Unfortunately with Hue Motion it doesn't work at all, even motion not work.
That's the only "zigbee" built in driver I know of that does illuminance. The "Generic Zigbee Motion/Humidity Sensor" driver does the other three Mike mentioned above but not illuminance, if that doesn't work either I'm out of suggestions.
All 3 Generic zigbee motion drivers report only motion status (and battery).
Also when I discover this device, it has 3 endpoints....can this be the problem?
On the generic zigbee motion/humidity driver, you will need to wait at least 5 minutes to verify no humidity, the device regularly reports this every 5 minutes unless there is a drastic change from the previous measurement. It may not show the device details upon immediate pairing, but when the device updates in 5 minutes it should if it is going to.
If no go this it sounds like they probably won't do it.
We don't have a driver that exposes everything this device is capable of producing, without me having a sample to investigate I can't speculate what the issue is or isn't, but it's unlikely the multiple endpoints are the problem.
Hello is it anything new about driver for this sensor?
Hi,
Same situation with mine, only motion status.
@martin.machacek.cz @joaomf The Tuya-multisensor 4 em 1 driver is now available here : [ALPHA] Tuya Zigbee Multi-Sensor 4 In 1
Hi @kkossev,
The 4 sensors are updating. I'll check at different times and compare it with other sensors I have here.
Thanks.
