Best way to return to Ethernet from WIFI mode?
I've been setting my C8 to WIFI mode in order to include some devices that require close-up pairing. Doing that through the GUI seems to work fine. What I can't figure out is how to easily return to Ethernet mode. Just plugging back in the cable doesn't seem to work. Disconnecting the WIFI through the GUI just leaves me disconnected. It always seems to require some combination of power cycling and/or network resetting. Am I missing some straightforward way of doing this? Thanks.
Just shutdown, unplug power, plug in the ethernet cable, then power back up. If that doesn't work follow @ogiewon 's instructions
Easiest way is to simply press and hold the network reset button on the bottom of the hub for at least 7 seconds. The hub will reboot itself and default back to using DHCP on the Ethernet port.
OK, thanks for the advice. I hoped I was overlooking some simple method that didn't require a long delay (i.e. reboot). It's quick to go from Ethernet to WIFI.
