Is the tv controllable via that driver? If so go to the device page on hubitat for it and do a screen shot (use windows snip) of the available attributes..
That driver requires the PairingKey which is never retrieved.
I was able to detect it by IP and Mac Address but the pairing key is just never retrieved.
At that point I would say add a power monitored outlet to your tv and monitor draw and use that draw as a trigger and when power <whateversetamount the rule ends
Maybe if you contact LG they can provide the key or maybe an "easter egg" hidden menu where you can see the key. Ya know help->about-> tap the version number 8 times=magic
I would agree that for my specific usecase, that should be enough. I was wondering if there was any suggested one to avoid purchasing the wrong one....
Someone suggested a CMARS one on a youtube video but wasnt sure if anyone here could give me some proved one =)
Since there’s apparently no way to get the pairing key oneself, I believe it’s the associated LG WebOS TV Discovery app that’s supposed to create the device and input that info for you.
I had a hard time getting my TVs to show up during that app’s discovery process.
Ultimately, it did work, and I’m not sure I can explain why.
Only thing I can think of is turning the TV off and on during the discovery process might have helped. And repeating the discovery a few times until the TV showed up.
@syepes probably wrote the most updated version of the driver and app code that’s been floating around since the thread linked above started a few years ago.
