I just installed a Inovelli Red Series Dimmer for my dinning room light. The light has 9 bulbs on it. I need some recommendations as to what the best bulb is to use now as I'm having issues with flickering and poor dimming now.
I had EcoSmart LED bulbs before the switch, they would dim great but did buzz a lot. After the switch the EcoSmarts would flicker no matter what even even setting the minimum level to the max of 45. I did some google searching and found where CNET said Philips had the best non-smart LED bulb for dimming. With the Philips installed the flicking and buzzing is fixed but dimming is basically zero with no noticeable change from 50% to 100%.
Any ideas or suggestions to help fix this problem?
