BE469 Schlage Connect Lock
I can’t find this on the device page anymore and there aren’t any posts about this lock on here in the past year. Was it removed from compatible devices or am I missing it?
Yes it was however I have joined the Hubitat family since it was removed and I got two of them up and running so you can just search for the public driver and install it. It was a little picky during setup but if you do a total reset on the lock before you begin you should be successful. You may find you need a zwave repeater as well as these locks seem to hunger for a strong signal.
After reset, use lock to remove all codes then add codes using Lock Code Manager.
Ya good point I forgot that even after the lock reset I had to remove some codes which seemed odd.
Thank you for letting me know!
I think these are the default codes that the lock comes with. When it resets it auto loads those codes.
Should just be the master code.
No. A reset clears all codes and installs the two default user codes in the first two lock positions. See the warning block from the user manual:
Huh. Didn’t realize that. I do know I did delete those as well before I tried to add my codes in Lock Manager.
These locks are picky. I have one. It works flawlessly, but I have 3 aeotec repeaters. I've found that having a repeater that supports beaming is the way to go. 3 z-wave locks and they're strong as ever after I added the repeaters.
I have one of these... Until the recent onslaught of Zwave issues it worked perfectly with lock manager, and joined the hub easily.
They really are good locks. Great customer support. I called asking about the radios and zwave / firmware issues. Told them for the most part my lock worked well but from time to time I have had issues. They just said they would send another lock lol. Told me to destroy the old one...
I didn't really think about that, I will contact them about my poor battery life and see if they can do anything.
