The ???? are in all 19 codes (2 included plus my 17). It seems to work though. I am a little snakebit to turn on encryption on the HE device options.
Just looking for why I am not seeing notifications or even debug messages in the logs.
Were the 17 lock codes added using HE Lock Manager? If not HE has no way to retrieve existing lock codes. I had a BE469 on Wink and initially had the same issue. In the end it was easier to delete all of the codes and add them again in HE.
Schlage locks do not allow the export of any codes resident on the lock, this isn't a Hubitat issue, this is what schlage decided to do.
All codes exported will show as ????, each one must be deleted and then entered again if you intend to do any type of code reporting or rules based on the entered code.
I reset the locks, then paired them with HE. On pairing, the two built-in codes were there after I paired. I then left them there and added the other 17 (mine) into all three locks. this worked eventually, but I did wind up having to retry several.
Now all the codes are in and work. They show up as ???? which is a minor pain but understandable if it is for security. This is not my issue unless it is a symptom of something else not configured correctly.
The trouble I am having is that the locks do not let me know via notifications or even logs that there has been a code entered (I would prefer to know the person, not the code).
I have a Lock Notifier that should let me know open/closed events and I have a Lock code Notifier that should let me know when any code has been used. It is these two things that are not working.
I did create the codes via Lock Manager, but they all showed up as ????.
I wasn't implying that this is an HE issue. The point I was trying to convey is that the lock codes must be deleted then re-entered in HE for them to show in HE.
This works for the BE469. For the FE599, any codes entered via Hubitat still show up as ????.
