Just to confirm -- that model # corresponds to a motion sensor -- is that correct?
Yes thatβs correct.
If you wish the battery reporting to be sorted using the stock driver, I'll need the device fingerprints for both of these
is this a contact sensor?
Yes, no temp
The device reports that it supports temperature (cluster 0x0402), have you tried the Generic Zigbee Contact Sensor with it?
I have not, I'll take look
Yes you are right, it must have just picked the non temp one? Looks like battery reporting has also gone to 100 as well. So could add its finger print to the genetic contact driver.
