Sorry if this is posted out there somewhere but I can't find anything that addresses what general expectations one should have after replacing a device battery regarding automatic HE recognition of the device, some almost auto re-establishment, or the need for a totally fresh pairing and configuration.
Just put new battery in Samsung Multipurpose Sensor and before I start deleting the old HE configuration and resetting the device to try to make it work again... I want to make sure I'm not missing the easy path.
Yes it has been dead for a week before I got to it.
So failing an all back to normal w/o intervention scenario the goal would be to rediscover the device and HE will recognize it based on the ID and prior configuration. Rediscovery is not necessarily a "start from scratch" process then. OK thanks,
