Battery operated radiator thermostat does not set temperature
Hi,
I paired a Danfoss TVR, yes oldy z-wave 300 based, but it is still working on an other hub I want to move away from. When i perform a Set Heating Setpoint it only works if I wake up the device right after running the command. In the log file I see the command, but at device wakeup it does not look that the HE Generic Z-wave Thermostat driver is actually sending any commands to the TVR.
Is the generic driver not supporting battery devices? Does anyone know a driver that would?
If I would to replace these Danfoss TVRs, does the hub support a FLIRS based one?
Thanks for any pointers.
Cheers Rene
O, bit of the log file:
2023-10-24 13:54:40.838 info Bedroom Thermostat thermostatSetpoint is 5.0°C
2023-10-24 13:54:35.813 info Bedroom Thermostat heatingSetpoint is 5.0°C
2023-10-24 13:54:35.807 debug ignore: WakeUpNotification()
2023-10-24 13:54:35.797 debug ignore: ScheduleOverrideReport(overrideState:null, overrideType:null)
2023-10-24 13:54:35.789 info Bedroom Thermostat battery is 90%
2023-10-24 13:30:17.017 debug pollDevice()
2023-10-24 13:25:14.259 info Bedroom Thermostat thermostatSetpoint is 5.0°C
2023-10-24 13:25:09.233 info Bedroom Thermostat heatingSetpoint is 5.0°C
2023-10-24 13:25:09.234 debug ignore: WakeUpNotification()
2023-10-24 13:25:09.205 info Bedroom Thermostat battery is 90%
2023-10-24 13:25:09.205 debug ignore: ScheduleOverrideReport(overrideState:null, overrideType:null)
2023-10-24 12:53:57.433 debug setHeatingSetpoint(8)
2023-10-24 12:52:07.120 debug setHeatingSetpoint(8)
2023-10-24 12:51:59.085 debug setThermostatMode(heat)
2023-10-24 12:30:01.085 debug refresh()
2023-10-24 12:26:19.065 info Bedroom Thermostat thermostatSetpoint is 5.0°C
2023-10-24 12:26:14.185 debug ignore: WakeUpIntervalReport(nodeid:1, seconds:1800)
2023-10-24 12:26:14.141 debug ignore: WakeUpNotification()
2023-10-24 12:26:14.044 debug ignore: ScheduleOverrideReport(overrideState:null, overrideType:null)
2023-10-24 12:26:14.043 info Bedroom Thermostat heatingSetpoint is 5.0°C
2023-10-24 12:26:14.022 info Bedroom Thermostat battery is 90%
2023-10-24 12:13:29.601 debug setHeatingSetpoint(10)
2023-10-24 12:07:46.320 info Bedroom Thermostat thermostatSetpoint is 5.0°C
2023-10-24 12:07:41.293 info Bedroom Thermostat heatingSetpoint is 5.0°C
2023-10-24 12:07:23.975 debug refresh()
2023-10-24 11:54:03.824 info Bedroom Thermostat thermostatSetpoint is 5.0°C
2023-10-24 11:53:58.804 info Bedroom Thermostat heatingSetpoint is 5.0°C
2023-10-24 11:53:17.685 debug setHeatingSetpoint(5)
2023-10-24 11:53:05.173 warn configure...
2023-10-24 11:53:05.103 warn description logging is: true
2023-10-24 11:53:05.102 warn debug logging is: true
2023-10-24 11:53:05.101 info updated...
2023-10-24 11:48:32.300 warn configure...
2023-10-24 11:41:55.989 info fingerprint mfr:"0002", prod:"0005", deviceId:"0004", inClusters:"0x80,0x46,0x81,0x72,0x8F,0x75,0x43,0x86,0x84", outClusters:"0x46,0x81,0x8F"
2023-10-24 11:41:55.986 debug building fingerprint for unknown Z-Wave device...
2023-10-24 11:41:45.969 debug getting device info in 10 seconds...
