Battery Operated Outdoor Button Options?
Does anyone know of any Battery Operated Outdoor Button type devices? Looking for something cheap. Zwave LR would be awesome but zigbee might work too. It's going to be about 30 ft from the house. Looking for something under $50 if possible.
Any ideas?
This is lame but I use Aqara/Xiaomi buttons in the yard-in a ziplock bag. :grin:
I have a repeater in my shed 15M away from the house. I have never unplugged the repeater to see if they work directly but given it's free space it should; I have 2 repeaters on each end of the house rear just inside the windows.
I’ve done the same thing as @dnickel. Only difference is that I seal them in partially vacuumed sous-vide bags.
Good ideas, I have both Aqara buttons and a sealer available.
These have two posts inside that respectively press against the top and bottom paddles of a Decora style switch:
Hubbell 5123-1 1-Gang Weatherproof Cover, Vertical, Decorator, White, Shrink
Other colors are available.
Mount a button underneath a post. Height of the button may be an issue, but it may be possible to shim a short post or shave a tall post.
I've been using Lutron picos, I have 6 of them outside none have any special weather protection, one is actually mounted on a block wall and is exposed to rain. Where I live we get temperatures from 25 to 125F, all 6 have been working flawlessly on the same batteries for almost 4 years now...
ive been using a freint smart button, but its zigbee.
I also went the vacuum sealer route suggested by @aaiyar and included a "dry-pack". It was a bluetooth temp sensor with LCD readout: In a shaded area, over an extended period, pooled water sitting above the screen was able to penetrate the plastic. It's entirely possible the plastic was damaged somewhere. Just something to bare in mind with placement. I intend to do the same thing when I get around to putting temp sensors in the fridge and freezer etc.
Cheers
