Battery "%" missing
It seems some device drivers do not report battery as a % and some do. Can this be changed so that they all report the same?
In making a dashboard for my batteries devices you can see some do, and some do not (makes for an ugly and inconsistent dash)
Built in drivers that (I have found ) do not send % are
Generic Zigbee Motion Sensor
Generic Zigbee Moisture Sensor
SmartThings Multipurpose Sensor V5
Also for some Devs if you could add it would be great (observation not complaint)
Roomba @aaron
Ring Range Extender @bcopeland
b-hyve @dman2306 :wink:
Contact the OP of the device drivers having an issue and ask them to change the event command to something like the following
 sendEvent(name:"battery", value:value, descriptionText:descriptionText, unit: "%", isStateChange: true)
The command is likely missing the unit "%"
Edit: Just noticed you already did that, anyhow above is the fix.
Top 3 are built in HE drivers, so I kinda am asking the OP.
But thanks for posting that hope it helps get it done. :wink:
BTW I prefer the actual Volts for battery reporting rather than the arbitrary calculated %
How did you get the icons that small? Is that a different program/skin/mod/whatever-you-call-it?
The icons are easy just go to Setting (gear) > Grid and adjust the Icon size there
The stock driver -which uses @bcopeland's code, IIRC- is the same way.
THe Generic Zigbee Motiion Sensor driver definitely sends the % in the unit field, where it belongs.
Just like the generic zigbee contact sensor.
I think this is a tile problem and not a driver problem.
Are you using HubConnect? If so there is a fix.
This is @csteele 's fix for the HubConnect app.
Remote Client -- Line 577 is Replaced with:
        currentAttributes << [name: "${it}", value: device.currentValue("${it}"), unit: it == "temperature" ? "°"+getTemperatureScale() : it == "power" ? "W" :  it == "voltage" ? "V" : it == "battery" ? "%" : ""]
Server Instance -- Line 895 is Replaced with:
       currentAttributes << [name: (String) "${it}", value: device.currentValue("${it}"), unit: it == "temperature" ? "°"+getTemperatureScale() : it == "power" ? "W" :  it == "voltage" ? "V" : it == "battery" ? "%" : ""]
That fixes all but the custom drivers then those are on that hub
Have tried a refresh or sync on the offending devices?
Edit: I guess if all was fixed except the custom drivers on that hub a refresh or sync will do nothing.
I know for motion sensors there is an issue with the tile. It puts the battery in the secondary (tile name) slot instead of the tertiary
Any chance you selected Attribute / battery instead of Battery for the Tile Template?
The Attribute / battery Template drops the "%".
