I see the Battery tile template switches the background color from green to red at some point as the battery level drops. Not sure what that level is, but I know I have different devices that have different low battery levels. My lock can still function down to 10%, while a smoke detector started chirping low Battery at 77%. Guessing there is no easy way to modify the color change level (per tile) or even adding an intermediate yellow, warning level?
Probably need to go to Hubigraph, Webcore, or something else? So far, I've stuck with the built-in Dashboard templates. Any suggestions?
You might wabt to have a look at the great Tile Builder app.
It can do many things and one of them is present the battery level according to your thresholds.
+1 for checking out Tile Builder
