It would be nice to have a way to queue up a batch of same device types for an OTA run. For me sitting at the terminal waiting for one to finish so I can queue up the next one is mind numbing.
I don't care how long the OTAs take, I would like to just commit the devices and then walk away. If it takes 3-5 hours for 17 device so be it. I just don't want to sit at the terminal for that long.....
I am on ZEN77 number three as I write this, 14 more to go........
My way is easier, I just never update Firmware. As a rule, I don't mess with working devices. I would only update firmware if it was needed to fix a known problem, or if it gives a new feature that I want to use.
Sitting here updating 19 ZEN77s at a residence. Will take several hours due to slow file transfer rate.
Second Request: Add a batch mode to Device Firmware Updater Tool. Just queue up all the like devices and let it run sequentially overnight. No need to set them up one by one....
p.s. Is there a way I could write a rule to manipulate the app to batch run the updates?
p.p.s. If batch mode too difficult can the app run multiple instances such that you can launch a few parallel firmware runs?
