Basic Z-Wave Tool
Updated this driver to include set and delete associations
	Basic Z-Wave tool updated by Anitesh Kumar (added set and delete associations)
	Copyright 2016 -> 2020 Hubitat Inc.  All Rights Reserved
	2020-08-14 maxwell
		-refactor
		-update VersionReport
	2020-08-12 maxwell
		-update with S2 support
	2018-11-28 maxwell
		-add command hints
	2018-11-09 maxwell
		-add association and version reports
	usage:
		-replace existing driver with this driver
		-set your paremeters
		-replace this driver with previous driver
	WARNING!
		--Setting device parameters is an advanced feature, randomly poking values to a device
		can lead to unexpected results which may result in needing to perform a factory reset
		or possibly bricking the device
		--Refer to the device documentation for the correct parameters and values for your specific device
		--Hubitat cannot be held responsible for misuse of this tool or any unexpected results generated by its use
import groovy.transform.Field
metadata {
    definition (name: "Basic Z-Wave tool",namespace: "hubitat", author: "Mike Maxwell") {
    	command "getAssociationReport"
	command "setAssociationGroup", [[name: "groupingIdentifier", type: "NUMBER", description: "Association Group Number", constraints: ["NUMBER"]],
                                         [name: "nodeId", type: "STRING", description: "Comma-separated list of node IDs"]]
        command "deleteAssociationGroup", [[name: "group", type: "NUMBER", description: "Association Group Number", constraints: ["NUMBER"]],
                                   [name: "node", type: "NUMBER", description: "Node ID", constraints: ["NUMBER"]]]
        command "getVersionReport"
	command "getCommandClassReport"
	command "getParameterReport", [[name:"parameterNumber",type:"NUMBER", description:"Parameter Number (omit for a complete listing of parameters that have been set)", constraints:["NUMBER"]]]
	command "setParameter",[[name:"parameterNumber",type:"NUMBER", description:"Parameter Number", constraints:["NUMBER"]],[name:"size",type:"NUMBER", description:"Parameter Size", constraints:["NUMBER"]],[name:"value",type:"NUMBER", description:"Parameter Value", constraints:["NUMBER"]]]
@Field Map zwLibType = [
	0:"N/A",1:"Static Controller",2:"Controller",3:"Enhanced Slave",4:"Slave",5:"Installer",
	6:"Routing Slave",7:"Bridge Controller",8:"Device Under Test (DUT)",9:"N/A",10:"AV Remote",11:"AV Device"
void parse(String description) {
    hubitat.zwave.Command cmd = zwave.parse(description,[0x85:1,0x86:2])
    if (cmd) {
        zwaveEvent(cmd)
//Z-Wave responses
void zwaveEvent(hubitat.zwave.commands.versionv2.VersionReport cmd) {
    Double firmware0Version = cmd.firmware0Version + (cmd.firmware0SubVersion / 100)
    Double protocolVersion = cmd.zWaveProtocolVersion + (cmd.zWaveProtocolSubVersion / 100)
    log.info "Version Report - FirmwareVersion: ${firmware0Version}, ProtocolVersion: ${protocolVersion}, HardwareVersion: ${cmd.hardwareVersion}"
    device.updateDataValue("firmwareVersion", "${firmware0Version}")
    device.updateDataValue("protocolVersion", "${protocolVersion}")
    device.updateDataValue("hardwareVersion", "${cmd.hardwareVersion}")
    if (cmd.firmwareTargets > 0) {
        cmd.targetVersions.each { target ->
            Double targetVersion = target.version + (target.subVersion / 100)
            device.updateDataValue("firmware${target.target}Version", "${targetVersion}")
void zwaveEvent(hubitat.zwave.commands.associationv1.AssociationReport cmd) {
    log.info "AssociationReport- groupingIdentifier:${cmd.groupingIdentifier}, maxNodesSupported:${cmd.maxNodesSupported}, nodes:${cmd.nodeId}"
void zwaveEvent(hubitat.zwave.commands.configurationv1.ConfigurationReport cmd) {
    log.info "ConfigurationReport- parameterNumber:${cmd.parameterNumber}, size:${cmd.size}, value:${cmd.scaledConfigurationValue}"
void zwaveEvent(hubitat.zwave.commands.versionv1.VersionCommandClassReport cmd) {
    log.info "CommandClassReport- class:${ "0x${intToHexStr(cmd.requestedCommandClass)}" }, version:${cmd.commandClassVersion}"
String zwaveEvent(hubitat.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
    hubitat.zwave.Command encapCmd = cmd.encapsulatedCommand()
    if (encapCmd) {
		return zwaveEvent(encapCmd)
    } else {
        log.warn "Unable to extract encapsulated cmd from ${cmd}"
void zwaveEvent(hubitat.zwave.Command cmd) {
    log.debug "skip: ${cmd}"
//cmds
def getVersionReport(){
	return secureCmd(zwave.versionV1.versionGet())
List<String> setParameter(parameterNumber = null, size = null, value = null){
    if (parameterNumber == null || size == null || value == null) {
		log.warn "incomplete parameter list supplied..."
		log.info "syntax: setParameter(parameterNumber,size,value)"
    } else {
		return delayBetween([
	    	secureCmd(zwave.configurationV1.configurationSet(scaledConfigurationValue: value, parameterNumber: parameterNumber, size: size)),
	    	secureCmd(zwave.configurationV1.configurationGet(parameterNumber: parameterNumber))
		],500)
List<String> getAssociationReport(){
	List<String> cmds = []
	1.upto(5, {
		cmds.add(secureCmd(zwave.associationV1.associationGet(groupingIdentifier: it)))
    return delayBetween(cmds,500)
List<String> setAssociationGroup(group, node) {
    Integer groupNum = group as Integer
    Integer nodeNum = node as Integer
    if (groupNum == null || nodeNum == null) {
        log.warn "Incomplete association group parameters supplied..."
        log.info "Syntax: setAssociationGroup(group, node)"
    } else {
            secureCmd(zwave.associationV1.associationSet(groupingIdentifier: groupNum, nodeId: [nodeNum])),
            secureCmd(zwave.associationV1.associationGet(groupingIdentifier: groupNum))
        ], 500)
List<String> deleteAssociationGroup(group, node) {
        log.info "Syntax: deleteAssociationGroup(group, node)"
    } else {
            secureCmd(zwave.associationV1.associationRemove(groupingIdentifier: groupNum, nodeId: [nodeNum])),
        ], 500)
List<String> getParameterReport(param = null){
    if (param != null) {
		cmds = [secureCmd(zwave.configurationV1.configurationGet(parameterNumber: param))]
    } else {
		0.upto(255, {
	    	cmds.add(secureCmd(zwave.configurationV1.configurationGet(parameterNumber: it)))
    log.trace "configurationGet command(s) sent..."
List<String> getCommandClassReport(){
    List<Integer> ic = getDataValue("inClusters").split(",").collect{ hexStrToUnsignedInt(it) }
    ic.each {
		if (it) cmds.add(secureCmd(zwave.versionV1.versionCommandClassGet(requestedCommandClass:it)))
String secure(String cmd){
    return zwaveSecureEncap(cmd)
String secure(hubitat.zwave.Command cmd){
void installed(){}
void configure() {}
void updated() {}
String secureCmd(cmd) {
    if (getDataValue("zwaveSecurePairingComplete") == "true" && getDataValue("S2") == null) {
		return zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
    } else {
		return secure(cmd)
